DIP Switch Settings: Off/On/Off/Off/Off/Off
Notice how the dip-switches correspond to 10,000 deg/min which offers a 6:1 ratio thus the Pulses per revolution should be set to 60,000.
Note that we have setup our rotary's headstock on the right and the tailstock on the left. You may need to check the "Invert Direction" checkbox if you put the headstock on the left.
