Home > Dominator CNC > Rotary > Molex Power Adapter
Molex Power Adapter
Do you have a 1f machine and need to connect up our rotary to your machine?  Then you're in luck.  This molex power adapter is exactly what you need to plug into the 1f's power box.
The molex side plugs directly into the 36v power supply box while the other SA 2-pin aircraft connector lets you plug the Rotaries power connector in.
