Keypad for AltMill
If you purchased the keypad mounting system for your AltMill then you're in the right place.
Here's the overall assembly image:
Best to assemble the triangular plastic part onto the triangular metal.
Then put the rectangular plastic part onto the metal part like this using the M5x25 socket screws:
Then... attach both metal parts together using the two M5 button screws
Next you'll want to attach the rectangular part to the L shaped metal using the triangular M4 screws and lock nuts:
Then.. install the keypad & mos from the VFD.  Remember you'll need the extension wires to make this happen that's included in your bundle.
You can set the cat5 cable aside as you can install that last.
The MOS switch we'd recommend preparing that by running the female side of the cable through the rectangular hole and attaching it onto the switch spades.
Then screw the MOS switch plate onto the triangular plastic piece like the following:
Lastly mount the whole assembly onto the altmill's leg using those two side screws.
Lastly... the user can take their e-stop and mount it to the two additional side-holes.
Finally you can plug the cat5 network cable into the back of the vfd keypad and plug it into your vfd.
You've successfully mounted your keypad and MOS switch onto the AltMill's Leg.
3 out of 3 found this helpful
