2 Inventory
You'll find several bags within the Bracketing System bag. Locate the bag of plastic parts and the screws bag for the Shapeoko Pro.
- (8) M5x20mm Button
- (2) M3x10mm Button
- (2) M5x15mm Button
- (8) M5 Nylon Locking Nuts
Also note that some of the plastic parts have one or more heat inserts already pressed into the part. These are not removable.
