2 Inventory
You'll find several bags within the Bracketing System bag. Locate the bag of plastic parts and the screws bag for the Shapeoko 4/Pro w/HDZ.
- (8) M5x35mm Button
- (2) M5x14mm Socket
- (2) M4x6mm Socket
- (2) #10 Washers
- (6) M5 Nylon Locking Nuts
Note: If there are extra hardware in your bag, consider them extra. The above hardware is all that will be required.
Also note that some of the plastic parts may have one or more heat inserts already pressed into the part. These are not removable.
