Home > Dust Boots > Boot Assembly > Assemble V5 Dust Boot
The difference between the 80mm and 65mm All-in-One Clamp
If using a 65mm Spindle, you'll need collar
Two mounting options for the hose. The Tube and a 2.5" Adapter
Glue the MagRing onto the Maglock Round as shown below.
Glue the other MagRing onto the tube as shown
Turn the Acrylic Tube over so the Mag Ring is sitting on a flat surface and glue the Tube Adapter onto the bottom.
Install the screw and nut on the spindle All-in-One Clamp but don't tighten down the clamp.
Install the Brush Material into the Brush track. Trim to fit.
*Note it will be a tight fit, a non-piercing device may be used like a small flat head screwdriver
Slide the V5 Boot onto the spindle, and secure with the (2) M5x30 screws
Use of the Spacer track is optional.
Finish by putting the tube in place and tightening down the loose screws. Install your hose onto the maglock round adapter with a clamp.
