The Tower Light is a visual/audio indicator system for your Masso Controller. Currently there isn't a dedicated audio output for an alarm state, and you can plug the white wire into either the red or yellow wire and the audible alarm will go off according to the chart below. You should not plug the buzzer wire in with the green wire.
After visiting the Tower Light Cable Inlet article and completing the wiring, only thing left is the programming
If you're looking to wire up the Light Tower, we have followed Masso's documentation exactly.
Please refer to their KB found here: https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/tower-lights
