Bracketing for Shapeoko 4
2 Inventory
You'll find several bags within the Bracketing System bag. Locate the bag of plastic parts and the screws bag for the Shapeoko 4.
  • (8) M5x20mm Button
  • (2) M3x10mm Button
  • (4) M4x12mm Socket
  • (8) M5 Nylon Locking Nuts
Also note that some of the plastic parts have one or more heat inserts already pressed into the part. These are not removable.
