May 31, 2024
The Internet of Things Manual Override Switch (IoT MOS) allows you to trigger the outlets on your IoT Power Strip without your spindle needing to be over ~5500 RPM.
It will still be able to turn on and off with the start of the spindle, but the advantage is that with the spindle not running you can flip the switch and override the relay turning the "Normally Off" outlets On and the "Normally On" outlets off.
