The QCW Mounts are made specifically for the Onefinity QCW Mount. The sandwich the bar that runs along the Y Axis.
When using a boot, you will need to plan for appropriate spacing both vertically and horizontally.
Pro tip: Use electrical tape to secure to the board rail while you screw it from the top.
You may need to modify the frame to accommodate for your bit depending on length and diameter
It has come to our attention that the design of the QCW has changed. They still work; however you will lose a slat, and they go on the inside instead of the outside of the T-Track
Old Style QCW
As Viewed from rear to front.
New Style QCW
As viewed from the front to the rear
New Style of QCW on the Left. Old Style on the Right
