You'll need to read this if you selected our ATC upgrade path.
After you've received your ATC System, and had it sent off for the V5 Upgrade (if necessary), you'll need to update the parameters on your VFD so that your new spindle will respond appropriately.
Chances are your traditional spindle system was a 2 pole, 400 hz motor (110v / 220v doesn't matter as long as the old system matches the new systems voltages).
The four parameters that need to be changed are:
| Parameter | Old | New |
| P0.0.07 | 0400.0 | 0800.0 |
| P0.0.08 | 0400.0 | 0800.0 |
| P0.0.15 | 0400.0 | 0800.0 |
| P5.0.15 | 6.0000 | 3.0000 |
To do that push "Mode", P0.0.00 will be displayed and the last zero will be blinking.
Navigate by pressing up and down, and the double arrow and view the parameter by hitting enter, and accept the change by pressing enter again, and mode to exit.
Here is a more detailed flow chart to explain navigating the parameters.
