The Cable Joints were designed for our ATC system, however they can also be utilized for a traditional water-cooled spindle system.
Our Samurai inspired cable organizer has 6 available areas for cabling, and the cable is designated specifically for it.
Our ATC System will come with a (4) pack of these little cable organizers. Unfortunately, they don't work on the motor side of the H20 and Sensor Cable connector, but after the connector they work great.
In our own testing, over a distance, they were best placed between 12-18". Further spacing can work dependent on the situation, but after 18" or so it the organization that it was meant to create was lost.
