Home > Spindles & ATCs > F. ATC (Subsection) > Installation > Understanding ATC Motor Connections
🧩 Understanding ATC Motor Connections — Made Simple
At first glance, the top of the spindle motor can look a bit overwhelming—but don’t worry. If you take it one connection at a time, the process is straightforward. Be sure to reference the images at the bottom of this article for visual guidance.
🔄 Pneumatic Connections
  • 6mm “Dust” Hose
    Connect the lower “dust” port on the Pneumatics Enclosure to the dedusting/air seal port on the motor using the 6mm hose with the Y-splitter.
  • 6mm “Tool” Hose
    Connect the upper “tool” port on the Pneumatics Enclosure to the motor’s Tool Change port using the second 6mm hose.
đź’§ Water Cooling Connections
  • The motor has two Kool connectors for water cooling.
    Each connector should be paired with a female Kool fitting and connected to your water lines accordingly.
⚡ Electrical Connections
  • Power (UVW) Port
    This connects to your spindle cable coming from the VFD.
  • NPN Signal Wire
    This connects via a smaller 4-pin connector to the MTR port on the Pneumatics Enclosure.
đź§° Cable Management Tip
Unfortunately, the NPN wire and spindle cable are longer than ideal (we would’ve preferred them about 12" shorter). While this can make cable routing a bit tricky, zip ties can help manage excess length. We're also exploring alternative cable management options for future improvement.
📸 Visual Reference
Scroll down to view step-by-step images showing exactly how these connections are made.
Let me know if you'd like to pair this article with a downloadable wiring diagram or printable quick-start guide!
2 out of 2 found this helpful
