The MagLock Brush will allow you to remove the hose from your boot or other tool, and attach a brush attachment for cleanup.
MagLock Round Adapter Sold Separately, and would be the hose side connection of generic flex hose (example 4" / example 2.5"), or PwnCNC Boot Adapter, and Converter for a proprietary connection
Comes in 2.5" and 4" sizes and is put together with superglue and the brush material is fed the same way as our boots.
