PwnCNC Boot adapters convert common shopvac style hoses using their connector to our family of connectors and we have several options available. Due to the nature of the design, there is no 4" PwnBoot Adapter.
The PwnBoot Adapters pair greatly with our PwnCNC Maglock Converter, which will then make any shopvac style hose we have an adapter for into a maglock hose. Then from there you can either use a Maglock Adapter to something like this to a tool like a table saw with a 2.5" port. You can also pick up a maglock brush and use it for general cleanup. The possibility and placement are limitless.
