2 Inventory
You'll find several bags within the Bracketing System bag. Locate the bag of plastic parts and the screws bag for the C4N48xx.
- (1) M5x20mm Socket
- (2) M5x25mm Button
- (4) M5x16mm Button
- (2) M4x8mm Socket
- (8) M5 Nylon Locking Nuts
Also note that some of the plastic parts have one or more heat inserts already pressed into the part. These are not removable.
