These are Keypad mounting options will allow you to mount your keypads in a convenient location for you.
All of our VFD Keypads will require you to have a hole for the VFD Extension Cable to fit through.
The makers files include a bonus alternative not shown here.
The left is the Surface Mount and the right is the Flush Mount and both would require the (2) #6 3/4" countersunk screws included.
The Masso Mount (those instructions can be found here) is an option to mount the surface mounted VFD Keypad Holder, or you can drill/cut an appropriately sized hole and screw it in place into a flat surface.
Simply pinch the keypad off and pull the keypad off your VFD. Disconnect the adapter & attach your VFD Extension Cable to the VFD port, string it through to where you have the Keypad Mount, and feed it through the back of the hole and plug it into your Keypad, then slide it back into your mount.
