The Maglock Converter is a Female PwnCNC Maglock Adapter and will connect to any of our PwnCNC boot adapters.
We also have male converters available here for hooking up to your dust boot directly
This is a two-piece system that involves the Magring and the female converter.
We've done tons of testing and this seems to be the simplest solution.
Apply a generous amount of superglue onto the inside of the MagLock Ring, and slide the ring onto the converter.
Allow the glue to fully dry before using.
An example application:
