Our Onefinity Foot Pads are designed to raise the entire machine by elevating the Y Feet. These are not designed to raise the X-Axis as they are sold as a unit of 4.
To install these, you will need to unscrew your current feet, lift up that corner and place them underneath, and reinstall screws, using longer screws if needed.
These are not compatible with the Foreman's Y-50 Rails and only the 35mm rails.
