Model: 1.5kw Pneumatic ATC
Speed: 0-24000rpm
Pole: 4 = metalworking
Frequency: 800Hz
Diameter: 80mm
Voltage: 110v
Phase: 3
Lubricate: Grease
Cooling: Water Cooling
Weight: 19.84lbs
Collet: ISO20 / ER20 up to 1/2" shank bits
Current: 12A
Bearing Type: 4 Ceramic
