Nov 15, 2024
903
Properly securing your stock is very important with every CNC operation. We have many clamping options, all low cost, and easily replaced if accidents happen.
The PwnCNC Lever Clamp was our first product, and is one of the few products that remains largely unchanged since initial release.
Featuring a sliding hole that allows to adjust the tension depending on the height of the workpiece and locks in place with raised ridges, and (2) notched ends so each side can be used as a clamping surface.
