Err29 Motor Over-speed Refer to the value of motor speed over P6.1.21 and duration of P6.1.22 Check whether the parameters of the encoder is set correctly; check whether P6.1.21 and P6.1.22 are set rationally; Check whether the motor parameter identification has been conducted;
