Err28 Larger Speed Deviation Refer to the value of speed deviation larger than P6.1.23 and duration of P6.1.24 Check whether the parameters of the encoder is set correctly; Check whether P6.1.23 and P6.1.24 are set rationally; Check whether the motor parameter identification has been conducted
