Err15 Frequency inverter Overheat Radiator temperature ≥ oh Detection Value (about 80°C, from temperature switch) Check the running slate of the fan and ventilation state Check whether the surrounding temperature is too high and the cooling measures are required to be take; Check whether the thermistor or temperature switch is damaged; Clear the dirt on the exterior of radiator and air intake;
