Err10 Motor overload Motor and current exceed the rated current Check the protection parameter P1.0.25 Reference of the motor is proper; Check whether the motor is in locked-rotor conditions or the load to motor needs to be reduced; Correctly preset the rated current of the motor Replace the frequency inverter with larger power
