Err06
Over-voltage at deceleration When the frequency inverter runs at constant speed, DC voltage of the main circuit exceeds this set value. The detected over-voltage value is the same as above
  • Check whether the input voltage is too high;
  • Check whether the bus voltage display is normal;
  • Delay the deceleration time;
  • Check whether the motor is dragged to run by external force in the process of deceleration;
  • Install additional brake unit and brake resistance;
ERR06 – Over-Voltage During Deceleration
What this means
ERR06 occurs when the VFD detects that the DC bus voltage rises above a safe limit while the spindle is slowing down.
When a spindle decelerates, it naturally generates energy. If that energy cannot be absorbed or dissipated quickly enough, voltage builds up on the DC bus. ERR06 is triggered to protect the VFD from damage.
This error happens while the spindle is stopping, not during cutting or steady operation.
Detected Over-Voltage Thresholds
The over-voltage limits are the same as other over-voltage errors:
  • Level S1 (110 V systems): ~240 V
  • Level S2 / T2 (220 V systems): ~400 V
  • Level T4 (380–480 V systems): ~800 V
Most Common Causes (Real-World)
1. Deceleration time is too aggressive
This is the most common cause of ERR06.
If the spindle is commanded to stop too quickly, the regenerative energy produced during braking overwhelms the VFD’s ability to absorb it, causing the DC bus voltage to spike.
This is especially common with:
  • Higher spindle RPMs
  • Larger or heavier spindles
  • Frequent stop/start cycles
2. Abrupt stop commands
Examples:
  • Emergency stops
  • Feed hold or program stop at high RPM
  • Tool changes that command rapid spindle stops
These force aggressive deceleration and can trigger ERR06.
3. External forces driving the spindle
If the spindle is still being mechanically driven while decelerating, voltage can rise rapidly.
Examples:
  • Tool still engaged in material during stop
  • Axis motion continuing briefly while spindle slows
  • Cutting forces “pushing” the spindle
4. High input voltage
If incoming line voltage is already high, the margin before hitting the over-voltage threshold is smaller, making ERR06 more likely during deceleration events.
What to Do First (Recommended Order)
Step 1: Increase deceleration time
This resolves most ERR06 cases.
  • Increase the VFD deceleration time
  • Avoid commanding the spindle to stop abruptly
⚠️ For Masso users:
Ensure the spindle deceleration time in Masso matches the VFD deceleration setting.
Step 2: Adjust workflow to avoid abrupt stops
  • Let the spindle coast down naturally when possible
  • Avoid stopping the spindle while fully engaged in material
  • Reduce reliance on emergency stops unless necessary
Step 3: Review cutting strategy
  • Ensure toolpaths don’t force the spindle while stopping
  • Avoid conditions where axis motion continues aggressively as the spindle slows
Step 4: Verify electrical conditions
  • Measure incoming voltage if possible
  • Confirm proper grounding and solid power connections
Step 5: Consider a braking resistor (advanced)
If ERR06 persists in high-speed or high-inertia applications:
  • A braking resistor gives the VFD a safe path to dissipate excess energy
  • Usually only required in more aggressive or production environments
Most hobby setups do not need a brake resistor.
Important Notes
  • ERR06 is a protective fault, not a hardware failure
  • It does not indicate a damaged spindle or VFD
  • Repeated ERR06 events mean the spindle is being stopped too aggressively
Summary
ERR06 means the VFD is seeing excessive DC bus voltage while the spindle is slowing down.
In most cases:
  • Increase deceleration time
  • Avoid abrupt stop commands
  • Ensure controller and VFD deceleration settings match
If ERR06 continues after increasing deceleration time, contact support with details about your spindle RPM, deceleration settings, and how the spindle is being stopped.
