Home > Spindles & ATCs > Technical - EM61 VFD > Compensating for Imperfect PWM Signals
Fine-Tuning VFD Settings for Hobby CNC Controllers
Many hobby and prosumer CNC controllers do not output a perfectly scaled PWM signal.
While a controller may be labeled as:
  • 0–5V PWM
  • or 0–10V PWM
In practice, the signal often looks more like:
  • 0–4.98V
  • 0–9.7V
  • or a non-linear range depending on load, wiring, and controller design
This is normal behavior for many hobby-level controllers and does not indicate a defect in the controller or the VFD.
Why This Matters for Spindle Control
The VFD uses the incoming PWM voltage to determine spindle speed. If the PWM signal never quite reaches its expected maximum or minimum voltage, you may see symptoms like:
  • Spindle not reaching full RPM
  • Spindle starting too fast or too slow
  • RPM not matching commanded values
  • Reduced control resolution at low or high speeds
These issues are almost always related to signal scaling, not wiring errors or faulty hardware.
How the VFD Helps Compensate
One of the strengths of the Delixi EM61 VFD is that it provides parameters specifically designed to:
  • Scale imperfect PWM input ranges
  • Adjust minimum and maximum frequency mapping
  • Improve low-speed behavior
  • Match real-world controller output instead of idealized specs
With a few targeted adjustments, you can often achieve very accurate and repeatable RPM control, even with less-than-perfect PWM signals.
What This Video Covers
The video below walks through:
  • Measuring and understanding real PWM behavior
  • Adjusting VFD parameters to match your controller’s actual output
  • Fine-tuning min/max RPM mapping
  • Verifying results safely without cutting material
This is a deeper, more technical walkthrough intended for users who want to dial in spindle control as precisely as possible.
Important Notes Before Adjusting Settings
  • This tuning is optional. Many users run successfully without changing these parameters.
  • Always make changes incrementally.
  • Test adjustments with the spindle unloaded before cutting.
  • If you are unsure, document your original settings before modifying anything.
When This Is Worth Doing
You may benefit from this tuning if:
  • Your spindle never quite reaches expected RPM
  • RPM changes feel compressed or non-linear
  • You want the most accurate speed control possible
  • You enjoy understanding how your system works at a deeper level
If your spindle behaves well already, there is no requirement to make these changes.
Summary
Imperfect PWM signals are common in hobby CNC systems. The EM61 VFD provides the tools needed to compensate for this and achieve excellent spindle control.
This video shows how to:
  • Adapt the VFD to your controller’s real output
  • Improve RPM accuracy
  • Get the most out of your spindle system
Take your time, make small changes, and use this information as a tuning resource rather than a required step.
