| Over-current at constant speed | The output current exceeds the over-current value while the frequency inverter is running at a constant speed. |
Causes that we have found have been an under powered motor being expected to do things it just can't. Example a 1.5kw and a 1/2" endmill at 400ipm.
If intent on using this endmill reduce depth of cut (typically enough without messing with numbers) and/or reduce feedrate and/or increase rpm
