Home > Spindles & ATCs > Technical - Power Requirements > What you'll need to power your 2.2kw 220v Spindle System
🔌 220V Power Requirements for Your PwnCNC Spindle System
If you're having an electrician install a new outlet for your PwnCNC 220V spindle system, please ask them to install a 20A, 220V NEMA L6-20R receptacle.
Your spindle system includes a 6-foot power cable:
NEMA L6-20P (plug) → IEC 60320 C13 (connector)
This connects directly to your VFD.
Need a Longer Power Cable?
If you need additional length, Amazon carries a variety of L6-20P to C13 cables:
🔗 View compatible cables on Amazon
For Our International Customers 🌍
We ship all 220V spindle systems with a U.S. NEMA L6-20P plug.
If you're outside the U.S., you have a couple of options:
  1. Cut off the U.S. plug and wire in a plug that’s compliant with your local standards.
  2. Replace the entire cable with a locally available C13 power cable, which is commonly used with computers and servers.
✅ Be sure that your replacement cable can support at least 15 amps at 220V.
Some international cables that should work fine:  https://www.amazon.com/dp/B0B2VHJSZL
23 out of 24 found this helpful
