We've discovered through a bunch of testing that the stock spindle plug on the new Warthog controller from Carbide3d just isn't good enough for 3rd party spindle kits.
Not to worry... we've developed a super simple workaround in the form of a simple pigtail wire that can be installed into your Warthog controller easily enough.
First step is to take a 30/64" drill bit and add a small hole to your controller's cover as follows:
Pro-Tip. Wait until after you're out of your CNC machine's warranty period before making permanent modifications to the machine.
Now install the pigtail into place and plug the 2-pin dupont connector onto the ICSP header.
Lastly seal your controller back up and you're all set for a plug-n-play experience.
And... finally, plug in the 6-pin control cable between the VFD and the controller.
