Manual and Programming
We ship our Version 4 spindle kit manual full-color printed.  It has not changed much from Version 3 other than the inclusion of our newest v4-enclosure photos and features.  In general it details many aspects required to install the spindle kit for many of the most CNC machines.
Be very careful performing certain actions described within the attached programming guide... some will wipe your VFD's programming and could void your warrantee.  It is recommended to only use the programming guide with our assistance.
You'll also find attached our v4 programming guide.  This paper includes our internal VFD Enclosure wiring diagram and VFD program settings required to make this all work.
Thanks to the inclusion of two GX12 connectors we're able to fully wire up the enclosure and only on rare situations require opening to change one wire.
We program the VFD with your motor and general settings on page 1 while page 2 outlines program settings and wiring specific to each control method.
Programming_VFD_v4.pdf
